Salta al contenuto principale
Repair guides and troubleshooting for the HP Chromebook, an 14 inch HP-brand laptop computer that runs on the Chrome operating system (OS).
27 Domande Visualizza tutte
Chrome is totally frozen, and Shift + Esc does not work. Unfreeze?
I cannot unfreeze Chrome on HP Chromebook. No keys do anything, and no cursor or trackpad function is working. How do I reboot it?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Try this first…
https://www.schooledintech.com/how-to-fo...
You have not indicated if the power button works or not. Try holding that down to power off. If that doesn’t work you may have to fully discharge the battery to power off… You can then recharge for a while and then power back up. If this recurs you may have bad hardware somewhere like failing RAM chip or something.
Punteggio 1
Try ESC - RELOAD - POWER
press CTRL - D
press ENTER
press ESC
Your data might be erased, but might not
Try and let me know
Punteggio 0
1 Commento:
Actually, I sort of fixed it. I just let the laptop run in its loop unplugged from the AC outlet and let the battery run down to zero. I was able to reboot the computer when I repowered it.
da
Aggiungi la tua risposta
Sean Foley sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 283
