Salta al contenuto principale
The Kenmore Direct Drive is a washing machine by Kenmore.
58 Domande Visualizza tutte
My Kenmore washer has no power
I have a Kenmore 600 Series washer top load no power. I unplugged it and plugged it back in then got an error message E2/F6 then the power went away again. I changed the electric control board on the washer still no power. I checked the outlet with several different things hair dryer and deep freezer they all worked fine but this washing machine won’t. Any suggestions.
Questa è una buona domanda?
Punteggio 0
1 Commento
@jo1oopsnb what is the complete model number for your washer?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@jo1oopsnb  for your washer this would be F6E2=COMMUNICATION ERROR UI TO CCU whc\ich means that “Communication between Central Control Unit (CCU) and User Interface (UI) has not been detected.”
The possible causes could be:
Check AC and DC supplies.
Verify continuity in cable between CCU (UI7) and UI (C2).
Use the attached Techsheet and check the wiring diagrams on pages 23–24. Techsheet for diagnostics
 You can also run the diagnostics test 1 and 2 and let us know what you find.
Punteggio 2
1 Commento:
Thank you for your help, this helped me fix the washer I had to replace the user interface panel on the washer.
da
Aggiungi la tua risposta
Joanne Joyner sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 34
Tutti i Tempi: 1,613
