Salta al contenuto principale
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Apple Hardware Test Failure Code: Help
Hello Everyone,
I was just playing around with my macbook 4,1 and decided to do Apple Hardware Test. Which resulted in
failure code: 4SNS/1/40000001: VG0C-0.070
I did some research and seem to indicate a sensor failure on the logic board. Though I have not had any no problems with this laptop for the last 8months(2nd owner) I was wondering if anyone could shed some more light on this error code and if I should be concerned
Thanks
Questa è una buona domanda?
Punteggio 3
2 Commenti
good job. Thanks for sharing.
da
Great. This Is Really Great Work.
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Apple doesn't tell the peons what those codes mean. But if you would like to spend about $47.50 they will tell you. Just call 1-800-SOS-APPLE. But my opinion is, "if it ain't broke, don't fix it".
Punteggio 6
You could try running Techtool Pro from Micromat.
I used to be Mac Certified - and I couldn't get error code info ?? !
Punteggio 1
Run the extended version of the Apple Hardware Test. Sometimes you will get an error if you run the quick version, and it may be something of a false positive. Some have found doing an SMC reset 3 or 4X can eliminate the error (note: a work around not a fix). If it is indeed a logic board error it points to a sensor(s) failing, VPOR might be VGC(VPU) related. You'll probably need a new logic board, AFAIK sensors as well as the VGC are soldered to the logic board which pretty much makes them non-DIY repairs, as soldering on logic boards are not for amateurs.
Punteggio 0
Aggiungi la tua risposta
Jamie sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,703
