Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modelli 1660, 1774 e A1785. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
1364 Domande Visualizza tutte
Earpice stops and sounds wierd
Okey so i have my screen replaced, after a while my earpiece starts to sound wierd, like static sounds when its playing music. After a while it stopeed working. I got it replaced, This has happend for the 3d time, im beginning to suspect there is something that makes the earpieceo bad and then stop working. Pls help
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
It sounds like it either isn’t being positioned properly, or the person who replaced it may have damaged the connector on the logic board. My suggestion would be to clean the connector very carefully with atleast 95% isopropyl alcohol, to prevent liquid damage. Making sure it is secured properly under the housing bracket, and on the logic board connector is crucial as well. If you do not feel comfortable doing this yourself, you should either seek out another person to repair it, or take it back to the same person at last resort and explain the issue. Good Luck
Punteggio 1
1 Commento:
Yes, im gonna take it to a repair shop, they have had it replaced the second time and now when i will replace it the third time i will tell them whats going on. Because it works fine for like 2 weeks, then it strts to go bad.
da
Aggiungi la tua risposta
Agge sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 35
