Salta al contenuto principale
Rilasciato il 19 settembre 2014, è la versione con schermo più grande (5.5") dell'iPhone 6.
1525 Domande Visualizza tutte
iPhone 6 plus no signal after touch ic repair
Hello,
I have a iphone 6 plus that had a touch ic disease so replaced the chip and made the M1 jumper. The phone works fine now except it has no cellular reception but wifi works great though. Any ideas on where to look for the problem? It worked fine prior to the repair.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Check the antenna interconnect wire on the back of the board and insure that the board was properly mounted in the housing. If all of that is okay, then you may have applied too much heat to the board and caused issues in the RF section, which is the bottom, front and back, of the logic board. Look for solder bridges, measure the BBPMU voltages etc.
Punteggio 1
Aggiungi la tua risposta
Hernando Berg sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 265
