Salta al contenuto principale
The Nokia Asha 201 is a Series 40 phone supporting dual-band GSM. Released in 2012.
Why is my phone vibrating and wont turn on
how can I stop my phone vibrating if it wont turn on I have tried pressing the power button for two minutes
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
anne Dawson  you did not tell us if anything happened to your phone prior to this. The vibrating is usually caused by your phone having failed its “self-check”. Most commonly it is a failed display issue. It is also possible that your phone has encountered problems with its software. You may need to reflash/update the firmware. Follow something like these instructions for that. Remember that with the update you will lose all data on your device
Punteggio 1
Aggiungi la tua risposta
anne Dawson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 996
