Salta al contenuto principale
Model No. A1367 / 8, 16, 32, or 64 GB capacity
Front Glass Not Staying
I followed all your directions which were "great" and got the itouch working. My only problem now is that I can't get the glass to click in or stay on. It appears that after I get one side in and try the other, that pushes that side back out. Can you offer any ffedback or suggestions on how i can resolve this and get the glass to stay on please? Thank you in advance, Ken
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I don't understand if you changed your digitizer? Did you move over the small metal hinge at the top of the old screen? That hooks in on the top. At the bottom (home button) you need a small adhesive like the one for iPhone 3G or 3GS. The screen should also snap into place on each side.
Punteggio 0
2 Commenti:
I think I know what you mean because I had the same problem today. Make sure the cable to the digitizer (the long thin one) is tucked underneath the top of the screen. If it folds out towards the bottom it will make the screen wiggle since it is like a spacer on the edge of the top part where the camera is. Hope you get what I mean.
da
Aggiungi la tua risposta
Ken sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 663
