blinkers not working on 2002 Pontiac Montana
Blinkers not working on 2002 Pontiac Montana. Hazards lights do work.
Questa è una buona domanda?
Turn signals work when the ignition is on; hazard lights work whether the ignition is on or not. The two systems have separate power supplies, with that being said you may have a blown fuse,
The instrument panel fuse block is located at the right end of the instrument panel, on the passenger’s side of the vehicle.
Hopefully this helps.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 102
