Salta al contenuto principale
Presentato a febbraio 2017, il G6 era lo smartphone LG al top di gamma ed era basato su Android 7. 0. La riparazione fisica di questo dispositivo può compromettere la sua impermeabilità rendendolo vulnerabile ai danni da liquidi.
56 Domande Visualizza tutte
Touch screen not working
I have a phone labeled “LG Fortune 2”, I chose “G6” because appearance-wise it was the closest, “Fortune 2” not being in the list of devices.
It got wet though not soaked - rained on , predictably would not boot. The moisture telltales all turned orange.
I dried it out and it booted fine, screen lights normally, but the touch screen will not work at all. The only way to get it to light is the home button.
What, if anything, can be done to correct this?
Thanks.
Questa è una buona domanda?
Punteggio 1
1 Commento
Thanks. I will replace the digitizer. I see they can be had for about $10.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Sounds like you need a front digitizer replacement. If that isn’t the issue, it could potentially be a logic board short. Water damage is tricky to diagnose directly, but I would try a digitizer replacement first.
Punteggio 0
As Jonathan said, water damage is tricky to diagnose. There may be corrosion on the screen connector causing the touch not to work. Its also possible a component on the board is shorted out. You will have to replace the whole screen assembly (glass, digitizer, LCD) if you want a new touchscreen because it is bonded together. A new screen will do nothing though if the corrosion isnt cleaned off of the connector, or if the logic board is shorted. Its going to be about the same or cheaper to replace that phone than fix the screen.
Punteggio 0
Aggiungi la tua risposta
Andrew sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,630
