Salta al contenuto principale
A1708 / EMC 2978 — Lanciato nell'ottobre 2016, questo MacBook Pro entry-level conserva i tradizionali tasti funzione (invece della Touch Bar OLED). La versione function key adotta l'Intel Core i5 e 2 porte Thunderbolt.
which adhesive tape to use for SSD replacement?
Hi,
I want to upgrade my 128Gb SSD but there is a black protection tape over it. I’d like to use a new tape when I replace my old SSD with the new 1T SSD…
I saw that the original tape is a multi layer one.
So what do you think ? which tape should I use ? polymide ?
Thanks.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Polymide tape should be fine.
If your careful you can lift off and reuse the original tape. It helps protect the connections under it.
Punteggio 0
2 Commenti:
Tesa tape is quite fine for this task too.
da
@ajcooke01 - Sorry no, this is where a single sided tape is needed not a double sided.
Look at Step 10 here Smontaggio MacBook Pro 13" Function Keys versione fine 2016
da
Hi did you find the right tape for the job? I having difficulty finding it myself.
Punteggio 0
Aggiungi la tua risposta
alain sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 503
