Salta al contenuto principale
The sixth generation Maxima, code-named A34, was only sold in the United States, Canada and Mexico. It was introduced in production form as a 2004 model at the 2003 North American International Auto Show.
My brake light on dash stays on
Parking brake switch, brake light on dash stays on
Questa è una buona domanda?
Punteggio 0
2 Commenti
You could bring it to the nearest Mechanic shop and get it fixed there.
da
Had all that fixed and it’s still on
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @pissingmeoff ,
The “brake” indicator light in the dash has two functions.
It indicates that the parking brake is applied and it is also a low brake fluid level warning light.
If the light is on with the ignition on but the parking brake is released then first check the brake fluid reservoir to ensure that the brake fluid level is correct.
If it is OK then perhaps there may be a faulty sensor in the reservoir or the parking brake switch may be faulty
Punteggio 1
Aggiungi la tua risposta
Robert Lewis sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 44
Tutti i Tempi: 3,496
