Salta al contenuto principale
Repair information for the Samsung Chromebook Plus. Released in February of 2017. Model number: XE513C24.
23 Domande Visualizza tutte
Replace keyboard on Samsung Chromebook PRO/Plus
I recently spilled liquid on my Chromebook Pro and some of the keys are no longer working. I tried to remove the keys to see if any residue was causing them to not work but to no avail. Is there a DIY to replacing the entire keyboard?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Risposta Più Utile
This is going to take replacing the entire palmrest, keyboard, track pad assembly for the most painless repair. The assembly usually runs between $50-80 and the repair should take about 30min if you're comfortable with laptop and phone repairs.
Punteggio 1
You’re better off sending it off to Samsung to deal with this one. Also, isn’t this chromebook quite new? You should check to see if it is still under warranty.
Punteggio 0
Unfortunately it's gen 1 purchased right after it's release date and out of warranty. Thanks for the suggestion though.
Punteggio 0
Aggiungi la tua risposta
Joe Dellava sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,025
