Salta al contenuto principale
Model A1318 / 32 or 64 GB capacity
20 Domande Visualizza tutte
Unlock my disabled iPod touch 3rd Generation.
The front screen is sjowing "Try back in 326,132 minuttes. Also im locked ot of my ipod.
Questa è una buona domanda?
Punteggio 37
7 Commenti
my ipod is disabled,it s sAY CONNEC TO ITUNES,HELP ME
da
what have you tried to fix it? Have you tried any of the above answers?
da
i have tried all of those answers and it still says the same thing.
da
Ariel Burns, I noticed you had left 2 comments at different questions. You might get better results if you ask your own question. Click on here http://www.ifixit.com/Answers/Ask/iPod+T... and give AS MUCH DETAIL as possible. Saying "I tried it all" is not going to work, since we do not know what all is :-)
da
My iPod says "iPod disabled try again in 8,060,999 minutes" plz help.
da
Mostra altri 2 commenti
Aggiungi un commento
14 Risposte
Soluzione Prescelta
You will need to restore it to regain functionality. This will delete all data on the iPod, including music, videos, apps, ect. Use this guide to put the device into DFU mode, then open iTunes. Select your iPod in the sidebar, and click restore. It will download the update, and restore the device to factory settings.
Punteggio 4
1 Commento:
The linked guide is related to iPhones but is NOT suitable for iPod 3rd generation, so I do not understand how is your answer helpful...???
da
Risposta Più Utile
I need intructions on how to unlocked my 3rd gen ipod please
Punteggio 5
This is one of my answer to the same problem that has been asked a few times on here."Apple says "If you cannot turn off the device using the slider, press and hold the Sleep/Wake and Home buttons at the same time. When the device turns off, release the Sleep/Wake and Home buttons." Now there is a way to erase the password but I am not sure if this would work when you are already disabled. This will not erase any data on your device. I guess you can always try and hope you have a windows computer :-) anyhow you plug in your iPod. Open My Computer (or Computer for Vista). Click on Folder options and enable to view hidden files. Next go to iPod_control and click on the folder named Device. If your iPod is locked, there will be a file _locked . Rename the file to _unlocked. Remove your iPod and it will be cleared" you can also check on here My iPod is frozen says I pod disabled?... The other thing you can do, is to plug your iPod in the computer that you normal use for it and see if it can be restored that way.Good Luck.
Punteggio 3
2 Commenti:
does this work on any ipod, ipad, iphone or just ipod?
da
What if it dont show up on computer
da
Ipod is disabled try again in 23,596,920 minutes
Punteggio 1
1 Commento:
I need help unlocking my iPod 3d generation that is disabled for 22,727,296
da
my ipod is disabled for 1,172,425 mintues help me out u mother !@#$%^
Punteggio 0
only apple broch not booting
Punteggio 0
1 Commento:
It may mean your iPod HDD is faulty.
da
i have a question anyone there
Punteggio 0
How I can get pattern lock in iPod touch
Punteggio 0
my ipod won't work please help
Punteggio 0
How do i reaset and store my ipod with a table no computer needed
Punteggio 0
1 Commento:
How do I reset an store my iPod with and tablet no computer needed
da
My iPod has a icon with a USB cable and the iTunes symbol. I can't get it open. Please help!
Punteggio 0
It says ur ipod is disabled and try again in 60 minutes so thats why i didnt tryed again. And the counting is still going on
Punteggio 0
This was just a waste of time Too Be Honest...Its not the answer im looking for. I clearly searched how to unlock IPod 3rd Generation when its disabled and this is what i get. :-| Like who do you hink you are sir?
Punteggio 0
1 Commento:
You simply need to connect your iPod to an iTunes and restore it to the factory settings - this will also set the proper date and time on your device. But before that, you want to replace the battery as this causes a commonly known problem with "try again with xxxxxxxx minutes" (date and time is set to 01/01/1970 when the battery is completely discharged or faulty).
da
I plugged my iPod into my MacBook Air and it said sync in progress. then it will let you re-try you “forgotten password”
Punteggio 0
Aggiungi la tua risposta
America sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 35
Tutti i Tempi: 42,368
