Salta al contenuto principale
Seconda generazione di iPhone. Modello A1241/8 o 16 GB di memoria/plastica posteriore bianca o nera. La riparazione è più semplice rispetto al primo iPhone. Richiede l'uso di cacciaviti e strumenti di leva e distacco con ventose.
1158 Domande Visualizza tutte
Replaced LCD and phone worked but ear, checked cables now no power
I have an iPhone 3G that had a shattered screen and LCD. I bought replacement parts and did the repair. Everything seemed to be working until I made a phone call and could not hear from the ear piece, only sound would come when put into speaker mode. I read that maybe connector 3 was not fully seated so I went back inside the phone and tried to re-position the connector, now the phone will not turn on. I plugged it in and even after awhile of "charging" it would not even vibrate when the switch was moved. Does anyone know what may have happened, and what I can do?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
check all your connections.. you may have dislodged the power flex (no. 5 or 6... the square shaped connection in the top left of your board) or the display isn't connected so you need to check 1+2, give them a firm press or they tend to pop off when you close up the display.
Punteggio 4
Aggiungi la tua risposta
Brandon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 720
