Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
Battery percentage won’t increase despite charging
Dear iFixit,
After self replacing 3rd set of new battery for 5s, I noticed the battery percentage won’t increase despite showing charging. I read similar problems and solutions, tried warming battery by hair dryer and charged to 100% once, but on next charging attempt same issue raised.
I read about missing F11 component, so opened the logic board and found it on place, but I doubt another component next to it to be missing. Please have a look on the picture and give your opinions.
I live in Nepal, where micro-soldering in unavailable.
Please suggest me what should I do; should I replace a new battery, or replace a logic board set with fingerprint sensor or should buy a new phone?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
The missing capacitor is right on the battery main power line, but I’m not sure it should completely prevent battery charging. I’m confident @refectio @rany @benjamen50 will be able to put a word of enlightment about it. However if the missing capacitor isn’t the only cause, next in the list would be a tristar failure which requires even better abilities for troubleshooting. I wouldn’t bother trying another battery purchase in any case.
Punteggio 4
3 Commenti:
The missing capacitor is a decoupling/bypass capacitor and is used to filter out noise. As such, it has no real impact on the actual charging of the battery.
In the context of a professional repair, I would replace it but in your case, nothing need to be done about this.
Check FL11 again to insure it is solidly anchored to the board. Sometimes it is only partially dislodged and it wont show up visually. Use a sharp needle and gently apply pressure on it to see if it moves.
da
Should I try a new set of battery? Batteries, here in Nepal, are always Chinese knockoff, which costs from $5 to $15. Even if you are willing to pay premium, you cannot find a good genuine battery here, so always cheap one works.
Also, there is no authorized apple stores, mostly electronic shops will import from Dubai or Singapore retailers with hefty price tag.
da
Thank you Arbaman & Minho for taking your time and giving me suggestions.
da
C275 which is the missing capacitor is used on the PP_BAT_VCC line which is used for charging up the battery.
Punteggio 2
1 Commento:
Thank you Ben for your response. But I didn't get what should I do next.
da
Aggiungi la tua risposta
Parikshit Singh sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 109
