Salta al contenuto principale
iPhone con schermo da 4" introdotto nel marzo 2016 con specifiche hardware simili a quelle dell'6s. Disponibile in Argento, Oro, Grigio siderale, Oro rosa con 16 o 64 GB. Modelli A1662 e A1723.
1049 Domande Visualizza tutte
How do I straighten the chassis entirely?
My aluminum chassis on my iPhone SE bent at close to a 22° Angle from the bottom side of the volume down button clear across to the top of the SIM tray, and it’s torn the bezel of the screen away from the interior of the chassis at the top of my phone, and partially at the bottom, WITHOUT breaking my screen at ALL (miraculously) and I was wanting to know if anyone knew how to bend that chassis back into shape right, or knew where I could just buy a replacement chassis? If anyone needs them, I actually have pictures of how it bent so people can see what I’m looking at, and are willing to share them as necessary
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If you want to straighten out the chassis, it’s important to remove everything inside the device. You would need to do this also for a replacement housing so check out this guide (it’s the 5S but very similar).
Then you lean the housing against a flat surface and bend it back into shape. It’s all trial and error and if you apply too much force, you could break the housing but at this point, you don’t have much to lose. If it doesn’t work out, you can always get a replacement housing on eBay or most reputable vendors.
Punteggio 2
Aggiungi la tua risposta
Christopher Brown sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,453
