Salta al contenuto principale
Modello fine 2011, A1278 / processore i5 2,4 GHz o i7 2,8 GHz
591 Domande Visualizza tutte
New SSD not detected In Disk Utilities
My dad gave me his old Mac Book Pro late 2011 after his hard drive failed. I upgraded to a 250gb Crucial SSD. And I formatted a USB bootable OS X Installer, like i’ve seen many people do. When I open up Disk Utilities Only my USB shows up but not my SSD. Could my problem be the internal sata flex connecter?
Help I’m beginning to feel discouraged about spending $150 on a 8 year old machine.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Two hard disks both failing might indicate it’s not a matter of faulty hard disks. As first thing yes, try a cable replacement, it’s a straightforward and inexpensive repair. If that doesn’t solve your issue it could be a logic board failure, but let’s hope it’s just the cable.
Punteggio 2
1 Commento:
I do strongly recommend putting in the newer cable design from the 2012 series: MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable - Apple P/N 923-0104. I also recommend placing some electricians tape on the uppercase where the cable rests to help protect it from the rough surface. And lastly, don't crease the cable! You want a smooth arc around the corners.
da
Aggiungi la tua risposta
seancamp23 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 150
