Salta al contenuto principale
Any way of removing the Blue Screw of Death on a PS3 Slim?
I have a PS3 Slim in which I was going to replace the hard drive on, however the blue screw to get to the hard drive enclosure is so incredibly tight that even with the most amount of force I can muster, I cannot, for the life of me, turn this screw even a bit. Any suggestions?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Try putting a towel with a lot of grip in between your hand and the screwdriver, hopefully the towel will increase traction between you and your hand. If your driver keeps slipping on the screw, stop trying to loosen it because you will strip the screw. Find a place that has the proper screwdriver for the job and take it there.
Punteggio 1
2 Commenti:
Thank you, I will try this as soon as I get home. Would using a pair of pliers around the screw be useful, or should I avoid doing that?
da
@solbady If the acrew is made out of zinc definitely do not do that but if it is steel then that might work.
da
Risposta Più Utile
I would take it into a hardware store and make sure you have the correct bit. You might need an impact driver or just more brute force.
Punteggio 1
1 Commento:
I will definitely do this if the paper towel solution doesn't work.
da
Aggiungi la tua risposta
Jordan Schivek sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,732
