Salta al contenuto principale
Released April 2016 by Yuneec Electric Aviation, Hexacopter Done with 4K UHD Camera
3 Domande Visualizza tutte
Need repair on our Typhoon H , who can we send it to?
Semi crashed drone , knocked off couple blades , 3 connector bolts for camera , need repair , Best Buy was total bust , whom can we send to for repair or is close to us that can work on it , we are in Hammond,La 70401
Questa è una buona domanda?
Punteggio 1
4 Commenti:
It was one of the boards inside that is gone I believe (GPS or main). I believe
My email is. gregmacmillan1958@gmail.com
My. Name is. Greg
Unique typhoon h drone
da
Hi Greg, if the GPS seems to be Stuck on "Acquiring" on the ST16 Display, the most likely cause is a Faulty Flight Control Module (FC) located on the main ESC Power Distribution Board, this seems to be a very common issue. The FC Module is something you can replace yourself, depending how confident you feel about removing the Top Shell of your Typhoon H, and Unplugging the FC Module, and Plugging in the Replacement, you can find a Replacement Flight Controller here; https://yuneecskins.com/all-products/ols...
da
If you would rather have it Repaired, thoroughly Tested & Test Flown, here is the Link to the Yuneec Repair Services; https://yuneecskins.com/yuneec-repair
da
I sent you an email Greg...;)
da
Aggiungi un commento
3 Risposte
Manufacturer repair service provider is: KAVService - https://kavservice.com/ . It took me eight weeks to receive my H520 back from Yuneec, and periodic updates were not provided as promised. Ordinarily, you submit repair/warranty claims thru the Yuneec website rather than direct to KAVService.
Alternative, third-party providers:
Carolina Dronz - https://carolinadronz.com/collections/dr...
FortressUAV - Plano, TX - https://www.fortressuav.com
Punteggio 0
1 Commento:
KAV Service & Carolina Drones are No Longer In Business - Permanently Closed
Fortress UAV No Longer Repairs Yuneec Drones
Yuneec Skins for Yuneec Parts - Yuneec Repair - https://yuneecskins.com/
da
Terrestrialimaging.com and they are in the USA authorized dealer/ service center
Punteggio 0
1 Commento:
Terrestrial Imaging No Longer Repairs Yuneec Drones - https://yuneecskins.com/
da
Yuneec Skins - Yuneec Parts - Yuneec Repair - Yuneec Batteries - NFZ Release - Yuneec Downloads - Typhoon H, H-Plus, H520 - Tornado H920 - Q500 - Mantis - Breeze - Hard to Find Yuneec Parts - Ships World Wide - Website; https://yuneecskins.com/
Punteggio 0
Aggiungi la tua risposta
Mitchell Black sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 406
