Salta al contenuto principale
iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
125 Domande Visualizza tutte
Going to install LCD screen
Hello, I am going to install the new LCD screen to replace my broken one.
Can anyone let me know any tips of DOs and DONTs? For example, the screen cannot be flipped more than 90 degrees because it will damage the ribbon. Any other tips I should know?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The best tip is to follow this guide very carefully. The iPad Air doesn’t have many gotcha’s but consider these:
  • Always disconnect/isolate the battery before disconnecting/connecting the LCD
  • The LCD is very fragile, handle with care
  • The screen flips to the right and the LCD flips to the bottom so you will need an extra hand or something to lean the LCD on until everything is disconnected
  • If you damage the digitizer during removal, don’t buy a cheap digitizer (you will regret it)
  • You have to be careful with how you fold the digitizer and home button flexes when re-assembling (they fold towards the inside of the device
  • You will need to remove the old adhesive and clean the ridge with acetone/IPA to remove all of the residue.
  • Then apply a good quality adhesive like this Tesa 61395 Tape you can find here on iFixit or pre-cut 3M tape from Bowler-Tech, which is what I use.
Immagine Tesa 61395 Tape
Prodotto
Tesa 61395 Tape
$5.99
Punteggio 1
2 Commenti:
I recommend that you get the adhesive remover so that you can remove the old adhesive quick and easy without the risk of damage.
iFixit Adhesive Remover
da
@ajcooke01 It's just Acetone...see Augustine's (@salmonjapan) & Robert's (@robert33415) answer here:
Is the iFixit adhesive remover just isopropyl alcohol?
Besides, as a chemical, iFixit can only ship it within the US.
da
Aggiungi la tua risposta
tikus belon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 43
