Salta al contenuto principale
ASUS ZenPad S 8.0 was released in August 2015. Model number: P01M with Intel Atom Processor Z3530
Why the tablet would only charge when it is on?
My Asus Zenpad  would only be charged when it is on. I have used the factory cable and charger (adapter) and also used others. the result is the same. It would charge when the tablet is on; it would not charge if the tablet is off.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi this could possibly be a battery or charging port issue. I would check the port and see if there are any bent pins on the inside of the port.
Punteggio 0
Aggiungi la tua risposta
phil philirvine sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 148
