Salta al contenuto principale
The Dyson AM07 is a bladeless tower fan released in 2014. The AM07 uses "Air Multiplier" technology to create a smooth stream of air without using visible blades.
Air intake on base totally clogged how to clean
On the base of the fan the intake totally clogged with dirt how do I take it apart to clean
Questa è una buona domanda?
Punteggio 7
1 Commento
It's got loads of dust coming out the holes I have COPD and wheelchair bound so I haven't got a clue I'm on my own?
da
Aggiungi un commento
4 Risposte
Risposta Più Utile
https://www.instructables.com/id/Dyson-A...
Please see the above article I posted on how to take apart and clean the internals of a Dyson tower fan.
Punteggio 3
4 Commenti:
Perfect cleaning manual!
da
Thanks!
If only I had remembered to take a picture before cleaning.. It was so full of dirt. as though Dyson had stuck one of their vacuum cleaners to a ring to come up with a fan.
da
Very good! I just wish that I’d looked online first it would have saved me so much time! I’m glad you put in that bit about the ring not being made to dissemble…….I thought it was me….I had spent ages trying to find release points but to no avail. Thank you rakone that was spot on.
da
Thanks! Glad my answer helped.
Do upvote it as i'm new here :)
I'll try to transfer over that instructables to ifixit soon.
da
Vaccum with a brush attachment..obviously use a powerful vacuum..this upkeep should be done biweekly
Punteggio 1
You can remove the cover and the filter of the tower fan with the help of this video here. You can then clean the cover and/or change the filter.
https://www.youtube.com/watch?v=UXwqFhfG...
Punteggio 0
1 Commento:
No Aaron, read: AM07, NOT the Pure Cool!
da
One way is to spray water on the inlet holes and clean the accumulated solid dust with a toothbrush.
Punteggio 0
Aggiungi la tua risposta
Whojuno sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 99
Tutti i Tempi: 65,128
