Salta al contenuto principale
Impara a conoscere le competenze di cui potresti aver bisogno per lavorare sul tuo dispositivo.
87 Domande Visualizza tutte
How to set up home network
I have a router in my living room and there is a cable that connects to dsl in the wall and there are telephone outlets throughout the house that receive telephone service once that dsl cable is plugged in. I have one in my room and I was wondering if I can use it to connect some sort of converter to use an Ethernet cable
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
If your home network is set up properly then you can use this particular cable to connect into the phone jack. I would at least try this and see you can get any Ethernet connection as I have this exact same cable in my bedroom too and it works great.
https://www.amazon.com/Honbay-Telephone-...
If you try this and it doesn’t work, your home internet is not configured the right way in order to do this. I would speak with your ISP as maybe they can set you up properly in order to do this.
Punteggio 0
Aggiungi la tua risposta
Jesse Phillips sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 47
