Salta al contenuto principale
The ATI Radeon X1900 XTX is a high-end graphics card from 2006.
How to repair a deadly graphics card
How to repair deadly graphics card
Questa è una buona domanda?
Punteggio 0
1 Commento
Hi Anmol tech
what do you mean? when you connect, what do you observe when you test the graphic card....
artifacts?
no display?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You don’t say what’s wrong with it or what you have tried. Is its presence recognised by Windows? Was it previously working but then failed, or is it one you’re trying to install? Does it work in a different machine? If it’s recognised, check for any available driver updates. Is your power supply sufficiently powerful to drive it?
Make sure the fan isn’t clogged with dust and is spinning freely when the card is powered up. Check that the gold fingers on the connector are clean an undamaged, and similarly the socket it plugs into. If it’s actually faulty then there’s probably not much in it which is repairable, realistically speaking.
Punteggio 2
Aggiungi la tua risposta
Anmol tech sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 537
