Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
My phone keeps freezing
I’m having a problem with my phone. It will freeze every little bit and in order for it to work again I have to turn my phone off then back on again and it works fine but then freezes again after a while.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Here’s a helpful article: https://www.appleworld.today/blog/2015/8...
The comment from Lloyd Shepherd might be the first thing to try: go to settings > general > dictionary and uncheck unnecessary dictionaries.
If it’s not spell check related, then it may not actually be freezing but rather becoming unresponsive to touch. If that’s the case, see Pam’s comment: “I read on a UK site that iPhone 6 can have a touch screen problem and recommended placing a coin just below the camera and inside a hard case to prevent a touch control from bending. Sounds odd but I did this and phone has returned to working order”
If none of that works then try to think when this started happening or what might be triggering it. An iOS update or a certain app might be causing your trouble.
Hope this helps!
Punteggio 0
Aggiungi la tua risposta
deidre2002 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 80
