Salta al contenuto principale
Il top di gamma Huawei nel 2016. Basato su un case unibody, ha una doppia fotocamera posteriore sviluppata in collaborazione con Leica. Può avere 32 o 64 GB di memoria interna e sei diverse finiture esterne. I numeri di modello sono EVA-L29, EVA-L19 ed EVA-L09.
72 Domande Visualizza tutte
How can I backup interal data of huawei p9 phone with broken screen?
Hello i accidentaly dropped my phone and the screen broke, and i was still able to use it but suddendly it started to work like $@$* and the screen stop working , then i got mad and i threw it to the floor and it was the end for the screen… the phone works but the screen doesn’t…. so does anyone know how can i backup all the internal data so i can replace the screen safely? (it doesn't have an sd card on it)..  thanks.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
If your huawei p9 phone with broken screen is still able to use, you can easily backup interal data of it. First link it to pc via usb cable, here you can try android data manager tool. With its help, you can easily access all data on it and export them to pc for backup.
Punteggio 0
Aggiungi la tua risposta
Fco sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 212
