Salta al contenuto principale
Xbox One S, progettata da Microsoft Corporation, è stata rilasciata ad agosto 2016. Xbox One S è una riprogettazione di Xbox One.
428 Domande Visualizza tutte
Replacing the joystick circuit board in my Xbox One S controller
I've been trying to replace the left joystick on my Xbox One S controller and failing miserably at removing the broken one with the soldering iron. So instead I want to attempt at just replacing the circuit board itself, but before I do I have a few questions.
  1. I'm going to use a circuit board from one of the older controller models for the first gen Xbox One, the one without a 3.5mm headphone jack. Will it be compatible with the Xbox One S controller I'm repairing?
  2. If it works, will the 3.5mm headphone jack still work even though the circuit board is from an older controller model?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Well there’s some good news, and some bad news.
The good news is that it looks as if you can put an original xbox controller board in a new controller body. Although I am not certain. Bad news is that the headphone jack will NOT work, as there is no physical connector to connect to on the older board.
Punteggio 0
Aggiungi la tua risposta
knarrmatt sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 13
Tutti i Tempi: 617
