I Forgot my log on pattern
How do you recover your logon pattern? I forgot mine.
Questa è una buona domanda?
Sadly you will have to factory reset your tablet in order to be able to use this tablet again. Factory resetting your tablet will erase all data stored on your tablet.
Ensure the tablet is connected to the charger and has at least 45% battery left. If the battery dies during this process the device could be damaged.
B) - A list of options in the top left of the tablet screen.
Six - Use Volume - to select "wipe data / Factory reset" and press the power button to select it
Seven - Use Volume - to select "Yes -- delete all user data" and press the power button to select it.
Eight - Following the reset, the device should boot up and go through the initial setup process again as when it just came out of the box.
Feel free to ask questions!
My laptop reset list is in Chinese which one is the factory wipe/reset
this won’t work for me
My screen doesn't look like that it all blue with different options and it says I don't have enough space to reset my laptop
What do I do if it says there is not enough space to reset the laptop but I can't log in to make space?
How do I reset a pin?
Ultime 24 ore: 1
Ultimi 7 giorni: 1
Ultimi 30 giorni: 10
Tutti i Tempi: 8,574
1 Commento
insignia tablet forget pattern
da Abid Ali
