How do you re-attach fallen-off keys on the keyboard?
If a Chromebook key is pulled off of a chromebook keyboard, how to you re-attach the key without the key immediately falling off again?
Questa è una buona domanda?
This guide should be of help for you. If the scissor mechanism is broken or if the little clips are broken on the bottom of the key are broken you will have to replace the key.
This article did not help me.
where can i replace a key
what store can i go to?
You can fix the scissor mechanism, just carefully take off another key and use that as a reference to putting it back together. If you snapped it in half or something, then yes it is unfixable and you need to get it replaced.
The link is about replacing the other keys, not the space bar. So for the OP's question, this answer is useless.
where do you go to get it "fixed" if the plastic piece is snapped in half? I have been told that our tech department has said there is nothing they can do.
Ultime 24 Ore: 5
Ultimi 7 Giorni: 39
Ultimi 30 Giorni: 160
Tutti i Tempi: 23,872
8 Commenti
thank you for your assentent
da THOMAS REAVES
how to fix a keyboard on a chrome board os?
da Kaleb Brown
Check this key clip to make sure it is not broken, Also check to make sure the peggs for the keyclip is not bend or broken. Then make sure that the bottom side of the key is also not borken. If all 3 of these are in good shape the key clip should snap on to the pegs, then the key should snap on to the key clip and all should be working fine.
da Bryan Swedhin
what store can i go to fix this key?
da Coach Eddie
I've repaired several of these. As long as the rubber cup is still on the keyboard, and it types that letter when you press the rubber cup. The key hinge clip and key its self are fairly simple to replace.
da Bryan Swedhin
Mostra altri 3 commenti
