Salta al contenuto principale
Lanciato a giugno 2012. Modello A1278. Processore Intel con Turbo Boost. Fino a 512 MB di RAM Video DDR5
1624 Domande Visualizza tutte
Replaced Battery, % Now Inconsistent, Coconut Batt says "Failure- yes"
I replaced the swollen OEM battery in my MBP 2012 with one from ifixit. However, since doing so, the few times I’ve had to use it away from a power source, the battery percentage drops immediately from 100% to 94% and then falls quickly until the MBP goes into hibernation at around 40% - I might get slightly over 2 hours use out of it.
I’ve tried the SMC reset listed here: https://ifixit-eu-en.helpscoutdocs.com/a.... No joy.
I’ve installed and run Coconut Battery, which says “Battery Failure - Yes” amongst other things (I will try to attach the screenshot)
Is there anything I can do? Or do I have a dud battery and need to replace it again?
Thanks,
David
Update (09/21/2018)
Coconut battery screenshot:
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You’ll need to get a replacement battery. There appears to be a problem with it. Look at your paperwork for the return instructions.
Punteggio 1
1 Commento:
Thank you - I will do that!
da
Aggiungi la tua risposta
David Fardon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 175
