Salta al contenuto principale
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Domande Visualizza tutte
820-2610-A : R5852 missing component?
Hello everyone,
if you have any idea where i should be looking for i am into it :)
i have no keyboard backlight, i have the trackpad detected ( no fan spinning like crazy ) but no button click and no movement detection; sometimes the trackpad seems a bit crazy when i am typing an internet adress, it does not move but clicks behind where i am typing and stays in the top left corner.
The webcam also does not work.
Keyboard, bluetooth, wifi works fine, the computer does not run hot.
The hardware components are fine, i changed the motherboard and the old one has no problem.
The new motherboard i have had liquid spill and the “tech” guy tried to take off oxydation… with fuel. I soldered back some components, and i have the older motherboard to compare.
That is why i am looking on the motherboard a missing or oxydated component: i was looking up the R5852, it seems missing on my new motherboard; weird thing, it is missing on my good one too. the good one does not start anymore because i killed it with a bad magsafe.
Maybe i soldered back my R5142 bad also.
If you could tell me what voltage i should look for and where, i would be eternally thankful.
Thanks a lot :)
here are some pics of what is missing!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
yanndetrie  this is only to answer your question about the component. R5852 is a “No Stuff” component. That means there isn’t one. It means that no components will be placed at that location on the board. To clarify in case this is unclear: There is no component that goes there.
Punteggio 5
1 Commento:
thank you so much :) any leads on where to start searching for my problems ( no keyboard backlight, no webcam, no trackpad ) ? thanks a lot
da
Aggiungi la tua risposta
yanndetrie sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 199
