Salta al contenuto principale
Modello A1502 con processore Intel dual core da 2,4, 2,6 o 2,8 GHz. Sul mercato dall'ottobre 2013.
552 Domande Visualizza tutte
Why does my mac freeze, then flash folder with question mark?
Often my mac freezes completely, and when I reboot it can’t find the startup drive (flashing question mark folder, disk utility does not see boot drive). After a few hours, it will boot normally. The problem comes and goes, but has been happening about every other day for a week. Running an Apple Diagnostics test gives error codes PPN001 and VDH002, but sometimes it gives no errors.
What is going on? I think the SSD works because other than the above issues, everything works well (runs fast, no problem opening/closing/saving files). Is this a cable issue? How can this be fixed?
Thanks!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
6 Risposte
Risposta Più Utile
That issue is to do with the storage drive not being detected via the system. It seems a bit odd that is only happening a part of the time. I’d recommend re-installing Mac OS and backing up all important data and see if this helps. If it doesn’t then it might be a physical problem with the drive itself, if this is the case open your laptop up with help from this guide: Sostituzione case inferiore MacBook Pro 13" Retina Display versione fine 2013
Inspect everything and see if there is anything around the ssd and/or ram that should not be there (Dust, corrosion ect.) . If there is, remove the component, clean it with rubbing alcohol and remove what should not be there, then and re-install it. Boot it up and if it still doesn’t boot you may have to replace the drive altogether. You should also check any cables in the system to see if there are any tears in them.
Punteggio 2
I would give a new SSD a try. If it turns out that a new SSD does not solve the problem then you can return it back to iFixit quickly and easily.
[prodotto collegato mancante o disabilitato: IF123-123]
Punteggio 1
Once you have it booted, go under the Apple in the upper left hand corner to >
System Preferences >
Startup Disk >
unlock it > select your internal drive >
close lock and restart and see if your problem persists
UPDATE
It sure makes us look stupid when you change the question after an answer has been given instead of adding new information as an update to the post!
Apple says
VDH002
There may be an issue with a storage device.
PPM001
There may be an issue with a memory module.
I would reformat the drive after booting from an external USB drive and try reinstalling the system. That failing go to @ajcooke01 Aaron’s solution.
Punteggio 1
1 Commento:
Sorry about that! I just thought the edit might be more helpful, thanks for the answer
da
In the event that you see a blazing question mark on your Mac's screen at startup, it implies your Mac ... On the off chance that your Mac shows a blazing question mark for a couple of minutes however then ... Your Mac should now start up without the blazing question mark (click here). ... things in your home organizer like your reports and things on your work area
Punteggio 0
I am experiencing the same problem, did you manage to solve it?
Punteggio 0
Can some body answer if this problem was solved changing between ssd?
Punteggio 0
1 Commento:
Yes it was. Using a adata ssd with sintech adapter now. Works perfectly since.
da
Aggiungi la tua risposta
Dimitri Coukos sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 8,655
