I press the power botton and will not turn on
I press the power botton and will not turn on. The small light in the front turn on and then off.
Questa è una buona domanda?
First try leaving it plugged in and charging for 30 minutes. What color is the MagSafe light? Now try starting. No? Try removing the battery and starting. Reseat the RAM. Unplug the machine and remove the battery and hold down the power button for 10 seconds. Do you have the original MagSafe adapter? Did you buy it new? Did you have any other problems before this started? Have you been into it? Any changes?
Please don't make me guess what your problem is. Did you do any of the things I asked?
when connected to the charger the battery charge fine. It does the light problem on battery. Could be the internal power supply?????
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,000
