Salta al contenuto principale
Modello A1502 / processore dual core Intel i7 2,6 GHz (Turbo Boost fino a 3,1 GHz) o 2,8 GHz (Turbo Boost fino a 3,3 GHz) con 4 MB di cache L3 condivisa.
494 Domande Visualizza tutte
Why is there a boot menu every time I turn on MacBook?
How to fix this?
Every time when I turn on my macbook pro mid 2014 I have to choose my startup disk to continue with booting. It behaves as if I am holding the option key...
However, the right option key doesnt work when I want to use it in the OS.
When I turn on MP and hold the left option key it starts booting without the boot menu, when I do not hold it it shows the menu.
When I hold the right option key there is no difference.
I have tried apple diagnostics and it shows that everything is ok.
Tried resetting SMC and PRAM and doesnt work.
Running MacOs High Sierra
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
After booting, go under the Apple to:
System Preference>
Start up disk>
unlock it>
select your boot drive
Punteggio 1
6 Commenti:
It didnt work
da
what system are you running?
da
Matej - Other than the option key not working while using macOS, is it that much of a bother to you? I mean, it can be a bit annoying to have to hit enter on the startup menu every time but you still get to where you need to go...
da
@mayer he/she is running High Sierra (hiss, High Sierra...)
da
Mayer - running High Sierra
Aaron Cooke - It is not annoying for me, but it is for my sister :D
da
Mostra 1 altro commento
Aggiungi la tua risposta
Matej sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 180
