Salta al contenuto principale
Il controller PS4 modello CUH-ZCT1. Rilasciato nel Novembre 2013 dalla Sony Computer Entertainment, la sostituzione della batteria da 3.7V di questo "six-axis" non è una riparazione complicata (N.B.: La guida di smontaggio NON è per questo modello)
387 Domande Visualizza tutte
PS4 controller is dead - Battery and USB port already replaced
As described in the title my PS4 controller is dead. The battery is charged, but the LED’s don’t turn on, even with USB cable connected. I already replaced the battery and I also replaced the lower part of the controller (the one with the USB port) with one of a working PS4 controller, which brings me to the conclusion that the main part of the controller (the one with the motherboard on it) must be damaged. I couldn’t find any visible damage. You should also know that, after I took the controller out of the closet to start repairing it, after I put the plug in, the controller worked once with LED’s blinking, but not anymore after I pulled the plug out.
I looked all over the internet to find a guide on how to repair the motherboard or anything related but I couldn’t find anything. You are my last resort. Thanks in advance <3
Questa è una buona domanda?
Punteggio 2
1 Commento
i presume you've tried resetting it ?
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
You could get this and repair it, seeing if it works.
DualShock 4 Controller Motherboard and Midframe Assembly (JDM-030)
If nothing else is working then replace the motherboard on it all together.
Immagine DualShock 4 Controller Motherboard and Midframe Assembly (JDM-030)
Prodotto
$29.99
Punteggio 1
I have a controller like that. The wireless, battery charging or turning on via battery doesnt work. I now use it on my desktop as wired controller. http://ds4windows.com/
You can sell it as a wired controller if it works that way, I personally dont think controllers are worth repairing.
Punteggio 1
Aggiungi la tua risposta
El Mero Mero sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,837
