Why is my Xbox One turning on randomly throughout the day?
Hi, I have had this white Xbox One for a while now and have noticed that it likes to turn on by itself randomly and stay on unless I go to power it off. However, even if I power it off and walk away and come back to it later, it’s on again! The only solution I have worked out is just keeping it unplugged until I want to use it.
This is not an optimal solution in the slightest. I have been reading and people have stated that static discharges may cause it to turn on randomly?
Steps I have tried:
- Plugging the power supply into a different power outlet.
- Performing a hard reset and changing the power settings.
- Placing it away from devices that could cause the static discharge.
- Using different controllers and USB Cable methods to power on the device.
- Checked to see if my controller was causing it. (No it hasn’t it doesn’t even turn on when this happens)
My Xbox One X doesn’t have this problem at all. And this only happens while leaving it plugged into its power supply. Other things to note, I do have an external Hard Drive attached to it that uses a power outlet to perform 14000 RPM versus 7200 RPM Hard Disk speeds. The HDD only turns on when the Xbox decides to turn on, on its own.
I have started to suspect someone has infiltrated my network and is playing tricks on me or is using my Xbox as part of a Zombie Net? However, when I check the display it’s doing nothing just staying on the home screen. So I will rule out any potential hacking or “ghostly” possessions of my device.
Questa è una buona domanda?
