Salta al contenuto principale
2.26 or 2.4 GHz / White plastic unibody enclosure
645 Domande Visualizza tutte
Can I quickly replace a cracked glass trackpad?
I recently dropped a tiny bit of water on my trackpad and the mouse started acting up.. moving on it's own..clicking everywhere. I wiped the water right away and opened the back case to let it dry. I used a blow dryer for a few seconds near the trackpad then put a regular fan next to the computer. Sadly after 4 days it's still not back to normal and I managed to crack the trackpad a tiny bit at the bottom as well so now I really want to replace it.
Someone linked me to this site but I can't find any tutorials on how to replace ONLY the trackpad. Is there an easier way to do it than having to unscrew the whole upper case?
I've never done anything like this in my life but I'm afraid I cannot afford to have it repaired at a shop (according to apple an upper case replacement is around 340$CND?) This is a Late 2009 machine.
Any advice for me?
Thank you very much
Claudia M.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
All you have to do is follow this guide to remove the battery and then follow steps 41 and 42 here on the upper case guide to replace the trackpad.
Immagine MacBook Unibody Model A1342 Batteria
Guida
Sostituzione batteria MacBook Unibody modello A1342
Difficoltà:
Facile
5 - 10 minutes
Immagine MacBook Unibody Model A1342 Upper Case
Guida
MacBook Unibody Model A1342 Upper Case Replacement
Difficoltà:
Difficile
2 hours
Punteggio 2
2 Commenti:
Thank you sooo much! <3
da
What he said.... ; )
da
Aggiungi la tua risposta
miracleshopping sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 4,190
