Salta al contenuto principale
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
Washer is blinking and error message
What does it mean when time remaining says 5d and the cycles are blinking
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
You probably used the wrong soap in the machine which resulted in excessive suds. Try a different soap which does not produce so much suds. You can read this guide for more information.
Punteggio 1
Aggiungi la tua risposta
Nora orso sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 377
