@ajcooke01
can’t give up on iFixit. Of course you tried the reset:
Unplug the multi-room interface power pack for a few seconds, then reconnect it. This allows the unit to reset itself after a power surge or power interruption.
and you tried to re-establish a connection:
If NO RESPONSE is continuously displayed, the link between your music center and the multi-room interface may be broken. To re-establish the link, hold the center close to the interface. Press and hold MUTE for about 5 seconds until you hear a second beep. After about 10 seconds, you should hear two beeps to confirm that the link is established.
Note: The music center establishes a link with the closest multi-room interface.
If you have the multiroom interface you could try to control it through a computer interface. Looks like the Bose Lifestyle all use the same serial commands:
COMMANDS:Setup....\x54\x41\x50\x0D
ON/OFF....\x61\x45\x40\x40
Vol Up....\x61\x45\x41\x41
Skip Reverse....\x61\x45\x42\x42
Play / Pause....\x61\x45\x43\x43
Skip Forward....\x61\x45\x44\x44
Vol Down....\x61\x45\x45\x45
NextDisc....\x61\x45\x46\x46
Video 1....\x61\x45\x47\x47
Video 2....\x61\x45\x48\x48
Aux....\x61\x45\x49\x49
CD....\x61\x45\x4A\x4A
AM/FM....\x61\x45\x4B\x4B
Tape....\x61\x45\x4C\x4C
Stop....\x61\x45\x4D\x4D
Mute....\x61\x45\x4E\x4E
Mute All....\x61\x45\x4F\x4F
Random....\x61\x45\x50\x50
Play....\x61\x45\x60\x60
Pause....\x61\x45\x61\x61
Fast Rev....\x61\x45\x62\x62
Fast Fwd....\x61\x45\x63\x63
Zone 1....\x61\x41\x01\x01
Zone 2....\x61\x41\x02\x02
If nothing, else this should work for you for more troubleshooting. 199402
Votato
Annulla
Punteggio
4
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
2 Commenti
To those who are experiencing their Bose Lifestyle 50 with the remote control saying “no response. I got the fix for you.
There are a possible 4 issues that can go wrong with the system.
1) The console cd exchanger,
2) The multiphase coupler
3. The Bose power supply
Or
4) the remote control . Not the speakers.
Start by changing and purchasing a Bose power Supply approx $16.
If that does not fix it than change the multi room coupler. Approximately $85.
If that does not fix it than change the remote control . approximately $75.00
My fix was the power supply and the multi room coupler.
My stereo works fantastic.
Let me know if this helps.
da jaimeltcdoctor
Want to get a hold of me e mail me jaimeltcdoctor@aol.com
da jaimeltcdoctor
