Salta al contenuto principale
Lo smartwatch Apple di terza generazione, con connettività cellulare opzionale, rilasciato il 22 settembre 2017
197 Domande Visualizza tutte
Apple Watch S3 Screen Replace - What adhesive + Apple Pay affected?
Hi friends. I purchased the ifixit Series 3 screen replacement and the ifixit Force Touch Sensor Gasket for Series 3 watch. The watch is A1860 (Nike + GPS + Cellular). I have two questions. Question 1: What is the proper adhesive replacement for the screen assembly? The 3M custom cut adhesive tape is not listed as compatible with this model/series. Does the force touch sensor gasket replacement include two sided adhesive itself so that no other adhesive is necessary? Do I need to replace that gasket if the screen just has a small crack? Question 2: If I replace the screen with the ifixit replacement do I need to worry about anything with Apple Pay working?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
The force touch gasket is a two-sided adhesive gasket which provides the necessary adhesion for screen replacement. If not using a new force touch gasket, then B-7000 adhesive can be used to seal up the display to the watch body.
Punteggio 0
1 Commento:
No one replied so I was able to solve this issue through subsequent research in order to work on a watch.
da
Aggiungi la tua risposta
drmdolfan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 324
