Salta al contenuto principale
The LN-T5265F model is a 52" HD television from Samsung.
35 Domande Visualizza tutte
it comes on or click on but mo picture
Hi my name is Sharon and model num is LN. T52685F. Serial num AJ33CFP801778P and it comes on or click on but mo picture but its sounding like it cutting on and of still no pucture at all.
Questa è una buona domanda?
Punteggio 0
2 Commenti
On and off tried unplugging and plugged back in still the same thing all it doung cutting on and off.
da
@jimarion54
no sound no picture, just clicking? you also seem to have to many numbers in your model description. Please let us know what exact model you have
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
@jimarion54
the clicking you hear is most likely the relay on the power board. We would have to see your boards to evaluate them for damaged components. You will need a multimeter to measure a few things later on. Make sure that you have a few hand tools and a meter before you deicde to work on it. First remove the back of your TV and take a good look around. Check the boards for any obviously damaged looking parts like leaky or domed looking capacitors etc. Then take some good pictures and post those with your question. That will allow us to see what you see.
Just by your sentence alone it appears to be a bad power board.
Check these things
Punteggio 1
Aggiungi la tua risposta
Sharon Eades sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 49
