Salta al contenuto principale
15.6", Intel HD Graphics, Core i3 2330M, Windows 7 Home Premium 64-bit, 4 GB RAM, 500 GB HDD
Nvidia graphics stop responding
Whenever i install correct nvidia drivers for my laptop it shows an error Nvidia kernel is stop responding and successfully recovered, it shows error in every driver package i install. This problem is occurring a month ago when my laptop controller is damaged so i gave it to dell shop they fix it and since this error is coming bcoz of this camera and sdcard reader is also not working..
Pls help
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Only thing that would come to mind for me is the fact that ‘kernel’ is memory associated. However I dug around and found this quoted on another site.
‘Use Run and type regedit
HKEYLOCALMACHINE > SYSTEM > Currentcontrolset > control > graphicsdrivers. Right click graphicsdrivers, click new >Dword (32-bit) value. Modify the value to 8
What I did next was delete ALL of my graphic driver installed (the nvidia one). It will swap to the build-in one on your motherboard.
Then use driver sweeper, select nvidia, and let it erase ALL of your nvidia driver files.
I then re-installed the nvidia driver through the installation CD I got with the graphic card, and did NOT get any updates.’
Punteggio 0
1 Commento:
I tried it but i always shows error "VIDEO TDR FAILURE " and also i tried out the method u show but not workig is my gpu is damaged or something...
da
Aggiungi la tua risposta
Pratik Gahane sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 19
Tutti i Tempi: 323
