Salta al contenuto principale
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
456 Domande Visualizza tutte
When I plug in my 3ds, the charger light goes on, but no power up.
So, I bought a 3DS for $20 from a thrift shop and they said it doesn’t charge. I opened the battery door and the battery has swelled up. But i thought I could power the system up without the charger…. but it doesn’t turn on. The charger port is also fiddely and I have to hold the charger in a weird way for it to charge. Could I need a new battery and charger port? Or is the whole thing busted and I wasted $20?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
You could try and fit a new battery first to rule that out, seeing as it would be the cheaper option. This is because most likely unless you’re great at multi-pin desoldering, you’re gonna have to replace the entire motherboard / pcb.
But for £24.24 ($31.25) you can buy a new / used board that’s been dismantled from a previous 3DS.
https://www.aliexpress.com/item/Original...
Punteggio 0
1 Commento:
So I tried a new battery and that had no difference. I took apart the whole thing and 5 of the 6 pins of the charger port had broken, so I resoldered them and now it works good as new.
da
Aggiungi la tua risposta
Hyrum Tripp sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 69
