Salta al contenuto principale
Shark Rotator Powered Lift-Away XL Capacity, model NV755. It can convert from a push vacuum to a hand-held vacuum. Repairs and troubleshooting found here may also be applicable to models NV652 and NV752.
Dust cup only fills at the top - have cleaned all filters!
I have a Shark Pet Pro-Liftaway, Model NV752. I recently changed all the filters, cleaned everything up, dried the filters thoroughly, and reinstalled. But only the top of the dust cup fills up; not the bottom. With 2 ragdoll cats and lots of wall-to wall carpet, I need to get this fixed. Help!!
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
3 Risposte
Hello! I recently started having the same problem as you and also after cleaning the filters. Have you found a solution?
Punteggio 0
I wish I could help you but this is also happening to me and I have a golden retriever. It’s very frustrating.
Punteggio 0
Same problem. Our new filters in blew air into hoses and nothing appears blocked. Could it be a problem with connections? Such as canister not completely back in place?
Punteggio 0
1 Commento:
Same here. What a bad flaw
da
Aggiungi la tua risposta
lesliejbrown sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 16
Ultimi 30 giorni: 38
Tutti i Tempi: 927
