Salta al contenuto principale
Repair and disassembly information for the second-generation Isuzu Rodeo.
8 Domande Visualizza tutte
2002 Isuzu rodeo it will turn over but won’t start
I replaced the fuel pump on a 2002 Isuzu Rodeo, V6 it started after I primed the fuel rail, the vehicle started up now it will turn over but won’t start, fuses check good, fuel pump comes on and vehicle has spark. Battery is new. What could cause it from cranking all the way over? been told the fuel pressure regulator could went out what do others think.
Questa è una buona domanda?
Punteggio 0
8 Commenti:
@texasrebel01 you got me a bit confused. Eiterh it does turn over (crank over) or it does not. If it turns over(cranks over) but does not start then you maybe looking at a fuel issue. We need to make sure that we understand the question before we can five you some decent advice.
Rep: 1
da
Yes it turns over but won't start
da
How can engine repair
da
Hi @dharmahema ,
Sorry to hear about your Isuzu being broken! We can’t provide you with any repair advice right now though because we don’t know exactly what we’re working with. Please update your post to include the make, exact model, Engine size, symptoms of your problem, and the troubleshooting you’ve already tried.
da
I'm having this problem too! I put a new starter new battery near starter relay, but will not crank over. It only clicks. Does not crank just one click at a time/key turn. Idk what to do or try?
da
Mostra altri 3 commenti
Aggiungi un commento
2 Risposte
Hi
Probably i know the answer to this.
  • Probably a fuel line leak
  • or the relay doesnt work (the fuel pump relay switch)
  • And have you check the fuel pressure in the fuel line when the fuel pump is running?
  • Hope this helps!
Punteggio 0
You have spark, you likely have air, and it is turning over the engine. Something in the fuel line is preventing the third fire requirement, FUEL, from getting into the cylinder.
The fuel pump is running, so it might be a regulator or something stopping th injectors.
Punteggio 0
Aggiungi la tua risposta
Richard sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 60
Tutti i Tempi: 2,946
