Salta al contenuto principale
Il Galaxy S7 Edge è la variante schermo curvo del telefono top del 2016 di Samsung, il Galaxy S7. Annunciato a febbraio 2016 e lanciato l'11 marzo. Modello SM-G935.
369 Domande Visualizza tutte
Accidentally disabled OEM unlock on rooted phone
I accidentally disabled the OEM unlock option on my rooted S7, and am now stuck in bootloop. I can get into download mode but not recovery mode.
I have tried to flash a stock firmware, however odin stops at this point:
<ID:0/007> Added!!
<ID:0/007> Odin engine v(ID:3.1301)..
<ID:0/007> File analysis..
<ID:0/007> Total Binary size: 4089 M
<ID:0/007> SetupConnection..
<ID:0/007> Initialzation..
<ID:0/007> Get PIT for mapping..
<ID:0/007> Firmware update start..
<ID:0/007> NAND Write Start!!
<ID:0/007> SingleDownload.
<ID:0/007> boot.img
<ID:0/007> recovery.img
<ID:0/007> system.img
<ID:0/007> FAIL!
<ID:0/007>
<ID:0/007> Complete(Write) operation failed.
<OSM> All threads completed. (succeed 0 / failed 1)
Is it possible for me to fix my phone, or do I need to buy a new one? if it is possible for me to fix it, how?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
You see the message custom binary blocked by FRP lock on the top left of the screen with the Samsung white text in the middle right?
Now there are only two ways to fix this and one involves factory resetting the phone.
You'll need to reflash stock firmware preferably the latest one via ODIN.
Once that's done you'll need to wipe data in recovery mode which means data will lost if it's stuck on Samsung logo, otherwise there'll be a button to press after boot to wipe data on phone.
Here is a guide on how to flash Samsung firmware if needed:
http://updato.com/how-to/how-to-install-...
If you have a GSM flashing box by any chance such as Z3X you can use the reset FRP/UFS option without needing to wipe data.
Punteggio 0
2 Commenti:
are you able to help with my error when trying this?
da
Make sure you are using Odin v3.13 or newer because it's required to flash 8.0.0 / Oreo firmware. If flashing firmware older than what's already on there it may not flash as well.
da
Aggiungi la tua risposta
Luke Hoskins sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,007
