Salta al contenuto principale
A1706/ EMC 3071 — Lanciato nel novembre 2016, questo MacBook Pro introduce la Touch Bar OLED. Ha CPU Intel Core i5 dual-core "Skylake"e 4 porte Thunderbolt.
239 Domande Visualizza tutte
Where is the fuse location on the board for mac pro A1706 backlight?
my a1706 mac book pro has no backlight, i can see apple logo on the screen with flash light. trying to check the back light fuse before i go to apple store for expensive repair.
But i don’t know where that fuse is located on the board. If anyone has that layout please help me
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
@mdesai7482 the backlight fuse is a 3A 32V in a 0603 package
Punteggio 0
11 Commenti:
@oldturkey03 Thanks but no luck fuse is ok. still have same issue.
da
@mdesai7482 if you have experience with board level repair you could trace your backlight circuit. If yo do not I suggest you contact those active users on here that do have the expertise and tools to do this for you. @tcrs_circuit in the USA @reecee in the UK and possibly even @refectio in Canada @arbaman in Sardinia (Italy) ;-) @rany in Lebanon and many others
da
Thanks
Do you know where is the connector for the backlight?
da
@mdesai7482 I do not quite follow you with that. What kind of connector? What is on your mind....?
da
Sorry, I mean any connector that relates with backlight, through which it gets signals from motherboard.
i don't have diagram so trying to trace the circuit of backlight.
or clean that connector see what happens. otherwise apple gave me estimate of $450 to fix it.
da
Mostra altri 6 commenti
Risposta Più Utile
Backlight failure other than the screen on these is rare. Fuse failures are almost non existent unless you plug the screen in with power. It is probably a LCD issue. Of course if you have obvious corrosion on the board, address that before blaming the LCD. I’d put my money on the LCD though.
Punteggio 1
1 Commento:
Since am also facing this issue, I have checked with the New screen, Still no luck. and also Fuse is okay, May I know where is the backlight IC located?
Sorry for the bad English!
da
Know this is old. But for future searchers.
Apple is offering a 5 year repair window on these, due to backlight cable wearing out prematurely. (apparently, just a little too short)
https://support.apple.com/13-inch-macboo...
and for do it your selfers with skills who just missed the warranty period…
MacBook Pro Retina (2016-2019) Display Backlight Cables
Immagine MacBook Pro Retina (2016-2019) Display Backlight Cables
Prodotto
$19.99
Punteggio 0
Aggiungi la tua risposta
manish sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 44
Tutti i Tempi: 3,695
