Salta al contenuto principale
Guides for the Wi-Fi version of the iPad Mini 3 (A1599). Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
20 Domande Visualizza tutte
Home Button Failure after Display Assembly Replacement
After a successful replacement of the glass on an iPad mini 3, the undamaged home button is not functioning when pressed. There are no errors reported on start-up. Given these circumstances, does this mean the connector on the logic board has been damaged? Again there are no signs of damage that I can detect.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Assuming you don’t have a teeny microtear in the flex then the MOST LIKELY problem is a parts problem on the screen. These are notoriously bad. Definitely make sure to test home button function before sealing it up.
Punteggio 1
Aggiungi la tua risposta
Michael Scott sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 57
