Salta al contenuto principale
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 Domande Visualizza tutte
Boots up when insert battery, can’t shut off
I am trying to replace a battery in a MacBook Air and as soon as I put the new battery in, the device boots up. If I then turn it off, it boots up again within a few seconds. It seems impossible to turn it off so it stays off. Does this mean there has been a short somewhere? There was no water damage that I know of (not my machine).
Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Reset SMC by Pressing shift + control + esc and use power button to boot into recovery mode in that there is an option to reset SMC
Punteggio 0
1 Commento:
Thank you for the reply!
Actually right after this comment I tried putting the new battery in again, and when it booted up I held the power button down to turn it off. Now, instead of starting up again right away by itself like it used to, it won´t turn on at all, even when plugged in with power cable. So not sure what´s going on there. Would this be a logic board issue?
da
Aggiungi la tua risposta
Vera sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 24
