Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
1041 Domande Visualizza tutte
Why is my bluetooth range so poor?
So recently I decided to replace the screen on my iPhone 6s plus. While researching parts, I decided also to re-shell the device, placing the internals from the original housing into a new home. The phone worked beautifully (or so I thought) for several hours and continues, even now, to function perfectly for everything (GPS, wifi, screen, battery) aside from bluetooth connectivity to headphones, speakers, my Apple Watch, etc.
The bluetooth signal is so poor (about 3 feet) — that my Series 1 Apple Watch is now essentially useless and my array of bluetooth headphones are also now ornaments only. What in the world is wrong with my bluetooth?
I have already replaced the wifi/bluetooth ribbon antenna (the curvy one) as well as replaced the grounding bracket and the NFC bracket. I am out of ideas for how to fix the issue. Any ideas?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hate to say this but it's probably bad antennas inside the housing which requires replacing it again.
Punteggio 2
Aggiungi la tua risposta
Patrick sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 3,637
